3354Views4Replies
Author Options:
How to build a USB pendrive at home? Answered
I want to make 16GB USB flash drive (pendrive) at home. But I don't know which chip is used to make a pendrive. So please provide me the information as if which chip should be used and also any other hardware to be used to make a pendrive. Also I want step by step tutorial to build a pendrive.
Thanks in advance.
mArisch
mArisch
3 years ago
Maybe you can with a Flash Memory Chip!
gizmologist
gizmologist
5 years ago
Maybe you could, but you'd spend 10 times as much money and uncounted hours working under a magnifying glass, and you'd wind up with something less reliable and far bulkier than the $10 flashdrives in the store.
steveastrouk
steveastrouk
5 years ago
Basically, you can't. You won't be able to buy the chip on small quantities, it will also be an extremely fine pin surface mounted part, on a very thin PCB.
Wired_Mist
Wired_Mist
Answer 5 years ago
Yhea you can't feesibly do that
Try buying a 16Gb drive and pulling it apart, that make your tut on Customising a pen drive
