663Views5Replies
How to build a mini high voltage generator?
I opted to make a mini high voltage generator for my project this semester. Anybody can help me or provide documents for it???
8 years ago
you could try making a flyback transformer.
essentially you get a 555 timer, and get it to work at between 10-20khz, with a potentiometer to adjust the frequency.
Use this to turn power on and off very quickly, using a transistor or mosfet, to a flyback transformer which can be found in old crt tv's and monitors.
it produces extremely high voltages, perhaps even in the millions, and its very easy to limit the current to make it safe enough to shock your self, while still keeping long arcs over 3cm long
8 years ago
Very small multi vibrator circuit with small transformer can provide you with high voltage with small 9 v battery input.
8 years ago
Van de Graaff generator
http://en.wikipedia.org/wiki/Van_de_Graaff_generator
About as high a voltage as a normal person can generate.
8 years ago
What do you consider high voltage?
You can make a little vandergraph generator. Do a search for it on the site and you'll find several instructables covering it.
Answer 8 years ago
high voltage as in not that high...even upto 220 V is fine enough
