342Views6Replies
How to build a vertical round sander?
Hello everyone. I recently started recycling empty bottle by cutting them and would like to build some sort of round sander that stands vertically on the ground or a table. I was thinking of maybe buying and old motor of some sort and attaching a piece of plywood maybe and just glue a sandpaper on it to sand of the edges off bottles to make drinking glasses or vases.Any advices would be appreciated or different ideas. Thank you.
3 years ago
https://www.instructables.com/howto/Spindle+sander...
mi8ght be helpful
Answer 3 years ago
I've heard that these are just way easier to buy than build.
But you can also use a drill press as a spindle sander.
Don't forget to wear a respirator when sanding glass!
Answer 3 years ago
In addition to head protection MENSA (Mouth,Eyes,Nose,Sound,Aegis) a vacuum to collect debris would make a lot of sense...
Answer 3 years ago
Very important safety note that. Yes glass should be either wet sanded (best) or with a proper respirator. Prolonged exposure causes Silicosis.
Answer 3 years ago
I mean, a spindle sander that oscillates all the time is a pretty difficult mechanism to build.
I drill press can be adjusted so you don't wear out the sand paper only in one spot.
But the simplest way is to attach a drum sander to a drill or dremel. I think...
Answer 3 years ago
Superb vid the motion is easily installed..
