106Views10Replies
Author Options:
How to burn arduino bootloader to atmega328p using arduino Pro mini? Answered
For past 3-4 hours I've been trying to burn arduino bootloader to atmega328p using a pro mini. But i can't figure it out. I've reffered to many tutorials and THIS one seems to be using a pro mini..
I've built a standalone arduino circuit according to arduino.cc's guide connected to the pro mini and when i hit "burn bootloader" it show the following error.
avrdude: Expected signature for ATmega328P is 1E 95 0F
         Double check chip, or use -F to override this check.
Wrong microcontroller found.  Did you select the right board from the Tools > Board menu?
But I'm using atmega328p. why does it say "wrong microcontroller found" ??
can anyone point me to the right direction?
steveastrouk
steveastrouk
4 years ago
Can you find a known good "328P" to test, and read back the signature bytes ?
Suraj Bhawal
Suraj Bhawal
Answer 4 years ago
Unfortunately no. I only have a pro mini and 2 atmega328p. Both are without bootloader... I've always worked with PIC so I don't even have an AVR programmer to begin with. I've searched online and here are many people who are having problems burning the bootloader.
steveastrouk
steveastrouk
Answer 4 years ago
I too struggled to get a valid bootloader into my own Arduino project. Can you erase your chips, or is the process failing before you can get there ?
In the end I bought a very cheap proper AVR programmer, but I used an Arduino based eraser to put them into a base condition.
AVR programming is only a kind of SPI banging.
Suraj Bhawal
Suraj Bhawal
Answer 4 years ago
it don't even recognise the chip... Any ways I've borrowed an avr programmer from my friend. I'll report back on how it goes.
steveastrouk
steveastrouk
Answer 4 years ago
Can you see the chip start its clock properly ?
Suraj Bhawal
Suraj Bhawal
Answer 4 years ago
Thanks.. but I managed to burn the bootloader using the USBasp programmer I borrowed from a friend.... But I still can't figure out why it didn't work using arduino pro mini as ISP.
steveastrouk
steveastrouk
Answer 4 years ago
Probably either timing or something about the line driving the pins. If you had a scope, I'd suggest you watched the lines, and checked rise and fall times.
iceng
iceng
Answer 4 years ago
I do a lot of PIC, by using a basic stamp to very easily work out software sequence action. Then compile the basic into native PIC code to be placed into a low cost PIC IC and adjust the code for about a 1/ 50X timing speed increase.
Suraj Bhawal
Suraj Bhawal
Answer 4 years ago
thanks! But I don't see how your comment helps my case.
iceng
iceng
4 years ago
Sounds like you are missing some bit definition of software.
