1102Views14Replies
Author Options:
How to calculate a Tesla coil semi spherical top load capacitance? Answered
I want to know if you can calculate the capacitance a Tesla coil semi spherical top load by calculating what it would be then halving it?
Also if that is possible could you third it or quarter it because I am going to buy metal bowls for it and most aren't quite a semi sphere (a lot only go about 120 degrees)?
steveastrouk
steveastrouk
Best Answer 9 years ago
It doesn't scale like that unfortunately, because of the way the electric field sets up around an object. On a sphere, that field is entirely uniform and forms concentric shells about the sphere. In anything not spherical, all bets are off.
Steve
The MadScientist
The MadScientist
Answer 9 years ago
That's what I thought would you know any way to calculate something like that?
steveastrouk
steveastrouk
Answer 9 years ago
It CAN be done, but it takes some extremely expensive software unfortunately. May as well just make it, then measure it.
The MadScientist
The MadScientist
Answer 9 years ago
How can I measure it multimeter's don't quite go low enough for measuring that kind of capacitance?
steveastrouk
steveastrouk
Answer 9 years ago
A classic method is to make it resonate with an air-cored coil, and measure the resulting resonance.
Steve
The MadScientist
The MadScientist
Answer 9 years ago
Unfortunately for me that can't be done because I am in the process of making a Tesla coil and I need to know a rough estimate of my secondary coil before I make the primary. I am going to make and measure the capacitance of my tank capacitor in the next few days.
steveastrouk
steveastrouk
Answer 9 years ago
Well guess then, from the spherical case.
The MadScientist
The MadScientist
Answer 9 years ago
I think I will make an excessively large inductance for the primary so I can move around the tap to tune it.
steveastrouk
steveastrouk
Answer 9 years ago
DO that, then rewind the coil when you find the sweetspot, to reduce losses.
The MadScientist
The MadScientist
Answer 9 years ago
Why can't I leave the windings there?
steveastrouk
steveastrouk
Answer 9 years ago
They can create addtional losses.
iceng
iceng
Answer 9 years ago
I'm curious, what will you do when you have a value for the capacitance calculation ?
Maybe test measure it ?
Here's the formula for the capacitance of an isolated charged conducting sphere,
                C = 4(pi)e0R
C   = capacitance in Farads
pi  = 3.14159 ratio of circumference to diameter of a circle
e0 = 8.854×10-12 permittivity of space
R  = radius of sphere in Meters
A
The MadScientist
The MadScientist
Answer 9 years ago
I will calculate the resonant frequency of my Tesla coils secondary.
iceng
iceng
Answer 9 years ago
You could calculate CLarge with the Largest Radius of your semi sphere
and also calculate Csmall with the smallest radius,
Then average the capacitance Cavg = ( CLarge + Csmall ) / 2
A
