66559Views21Replies
Author Options:
How to calculate the total time a battery can operate light? Answered
hi,I am willing to just use solar panels to recharge my batteries and then to power my garden lights.  What I need is how do I know if my battery will be able to power my lights for atleast 24 hours.  How do I choose the solar panels to be able to charge the batteries. IF I know how to calculate for atleast one light and battery that should be enough for me to calculate for my whole system.
Thanks
paulela1234
paulela1234
8 months ago
I am doing about the same. Using a solar power car battery charger with 2 car batteries in parallel for longer power watts. Are you successful so far?
pettechnicianprofessional2013
Reply 6 months ago
Not helping. What she means is that how many hours for garden lights to operate on battery alone after charging for whole day with solar..
Shamsu f jahun
Shamsu f jahun
8 months ago
I have 200ah×2 my loads is750 watt it take me 12hours
Colskin
Colskin
11 months ago
I want to run all my led down lights on battery & solar.
They are 12 volt 10watt led down lights
I have 20 in the house?
Nehal Agrawal
Nehal Agrawal
1 year ago
I want to know how much time did the solar lamp work in one charging?
petrusha2610
petrusha2610
1 year ago
Is it really that simple way to know battery can light on our lamp? I just know every hour battery voltage will drop down and lamp also have low voltage range for on, when battery just below low voltage lamp, the lamp will off...my question is about when battery voltage drop, is lamp will drain more current or not from battery to turn on lamp with max lamp watt...(lamp 12watt, when battery 12v then current 1amp...battery drop to 10v, is current increase to 1.2amp?)...when battery cant support what lamp need then the lamp will drop the brightness...make me confuse to complex to understand...thank you
DatoL1
DatoL1
1 year ago
Josehf Murchison
Josehf Murchison
7 years ago
watts hours/watts/2
Watts are volts x amps.
Battery in watt hours (Storage capacity), light in watts and discharge till the light wont work (About Half to be safe).
You can do the same with amps.
Light in amps, battery in amp hours (Storage capacity) and discharge until the light wont work (About Half)
So a 5 amp light will stop working when running on a 10 amp hour battery in one hour.
Does this help?
Joe
ajaypatil97
ajaypatil97
Reply 1 year ago
Can u please help me for a small thing...
Suppose I have 3 watt bulb running on 7.5 Amp-hr battery, so for what time it would glow......?... Please reply sir
Josehf Murchison
Josehf Murchison
Reply 1 year ago
Sorry for taking so long to reply.
Convert the battery to watts.
E x I = W
6 volts times 7.5 amp hrs = 45 watts hrs
6 x 7.5 = 45 watt hours
45 watt hours divided by 3 watts = 15 hours
45 / 3 = 15 hours
Since the light will fail before 15 hours it should be good for 10 hours.
kevovek76
kevovek76
2 years ago
I'm looking for some help. What I'm looking to do is run a 18w led dc volt flood light on a 12v battery charged with a solar panel. Can someone tell me how long the light would burn on a 12v dc battery. the flood light I'm looking to use is the RAB FFLED18DC. also what size panel I would need. Please help! Thanks in advance
raghvendras4
raghvendras4
2 years ago
You can do that for 60/55 w if u really want to do for that u have to install atleast 9 ah 12 v battery and weakly charge it by a battery chargr apart from vehical charger circuit
Chamburn
Chamburn
7 years ago
well for example I already have a 12 volt 1 watt Led light and also a small sealed battery with 12v 1.3ah.
bwrussell
bwrussell
Answer 7 years ago
Watts = Volts x Amps
1 W = 12V x i, i = 1 W / 12 V, i = .083 Amps
Time = (Amp-hours / Amps) / (Safety Factor)
t = (1.3 Ah / .083 A) / 2, t = (15.6 hours) / 2, t = 7.8 hours
You should be able to maintain full brightness for ~ 8 hours depending on how efficient your driving circuitry is and you only run the LED off of the battery.
Do you understand the equations? Try different numbers and make sure you understand how different power lights and capacity batteries will effect the time you get.
rajeshsd
rajeshsd
Answer 5 years ago
can you explain how did you put the value for the safety factor?
bwrussell
bwrussell
Answer 5 years ago
It's an arbitrary number really. Mostly it takes into account any inefficiencies in the battery or circuit. It also would help extend the light if you had a couple of days in a row without enough sunlight. You can reduce that number at risk of not having enough power to get the light all the way through until the panels take over again.
Chamburn
Chamburn
Answer 7 years ago
Hi, yes I did understand the equations and already got all the required components but now I don't really know If I really need a transformer to power my 12 volt lighting system or can I just connect my lights directly to my battery or timer.
bwrussell
bwrussell
Answer 7 years ago
That depends on how the lighting is arranged and what the source is. Is it a single 12v light or multiple sources? What are the specs of the source? You can use any DCV as long as it meets the min required by the sources and you have the right resistance. The closer the input voltage to the required voltage the better though, any excess will be lost as heat through the resistor.
steveastrouk
steveastrouk
Answer 7 years ago
Using BWR's numbers, in other words, that little battery doesn't hold enough to carry you through a SINGLE night, so to begin with, you need a bigger battery - don't aim to flatten it overnight either, aim for say 25% of capacity, tops, so shoot for a 30Ah battery. Which you need to charge with the available daylight in say 10 hours, so you need 750mA@12V from your solar panel,
steveastrouk
steveastrouk
7 years ago
Start with your lights. How many volts and how much current do they draw ? How long will they be on for, in the worst case ?
Chamburn
Chamburn
Answer 7 years ago
hi, Yes it did help however I need to know how to connect the lights together as Normally I would run a single wire then connect the lights to it but the problem is I don't really know how to make the connections to the main power cable where I would use parallel connection setting. How do I need to connect the lights so that in case one breaks down all the others kept on lighting.thanks
