257Views5Replies
Author Options:
How to charge a 4V 1000 mAh SLA Battery, can I use a 5V 2A charger? Answered
_Boltz_
4 years ago
never use that directly, instead use a 5v 350ma power supply with a 1N4007 diode,
_Boltz_joelashir
Answer 4 years ago
please select this as "Best Answer" if you appreciated it ......... :) , thanks......
Downunder35m
4 years ago
2.25 - 2.3V per cell, which means you only need an absolute max of 4.6V - anything above and your battery will start to gas out.
If you have a box of junk electronics see that you can find a diode with suitable voltage drop of around 0.4V- 0.5V.
If your charger provides a bit over 5V with no load a standrand 4007 diode should do the trick.
You should also consider a resistor to limit the charging current.
With that added to the diode and the output voltage between 4.5 and 4.6V you are good to go.
