468Views10Replies
Author Options:
How to combine 2 audio signals from HDMI Answered
As I've known so far there aren't receivers that mix audio.
I want to mix 2 HDMI sources, lets say 1 is a PS4 and second is Xbox One, how would I mix them in 7.1? Mix the 2 audio sources into 1, is there a way of doing that? What is the simplest way.
I know that there are stereo mixers, but haven't heard of a HDMI one.
What is the simplest way of mixing both signals?
I think it might have something to do with modulating the signals, but I dont specifically know how modulators work.
rickharris
rickharris
1 year ago
For me I would play the HDMI signal through my PC, Use Audacity (free) to record it. Then play the second one and record it. Use audacity to mix both sound captures and output as you want.
MatanY2
MatanY2
Reply 1 year ago
what if i'd buy a receiver, is there a receiver that can mix hdmi audio inputs?
rickharris
rickharris
Reply 1 year ago
Not that I know about. But your PC probably has an HDMI input on it.
MatanY2
MatanY2
Reply 1 year ago
i have a thunderbolt connection though if that helps, no idea if it's an input or output.
MatanY2
MatanY2
Reply 1 year ago
i have hdmi outputs but not hdmi inputs.
Downunder35m
Downunder35m
Reply 1 year ago
No receiver but you can try so called audio inserters.
Usually they only have one HDI pass through with the option to mix RCA or optical audio signals in.
But there are some that offer two or more HDMI inputs.
MatanY2
MatanY2
Reply 1 year ago
how do the audio inserters help me? i connect the hdmi output to its input and then what? how can i listen in an output?
Downunder35m
Downunder35m
1 year ago
You would need a dedicated mixer for this as HDMI is not just "some audio signal".
All is digital and in many cases you won't even have the same standards in use for both devices.
MatanY2
MatanY2
Reply 1 year ago
MatanY2
MatanY2
1 year ago
is there such a mixer?
