256Views4Replies
Author Options:
How to concatenate two or more linear interpolants? Answered
I have a graph, it is not a straight line but a random curve, I want to do linear interpolation of different data set points. I read it here:
http://en.wikipedia.org/wiki/Linear_interpolation#Interpolation_of_a_data_set
And it says that:
"Linear interpolation on a set of data points (x0, y0), (x1, y1), ..., (xn, yn) is defined as the concatenation of linear interpolants between each pair of data points."
So. how can I concatenate two or more linear interpolants?
And can you please also give an example of it?
kelseymh
kelseymh
Best Answer 7 years ago
Linear interpolation only involves two points: By "concatenating," the text means that between (x,y)0 and (x,y)1 you use one interpolation function, then between (x,y)1 and (x,y)2 you use a new interpolation function, and so on. At the point where they touch, (x,y)1, both functions will give the identical result (namely, (x,y)1 itself). Of course, with linear interpolation you will not have a smooth first derivative.
For the region (x,y)0 to (x,y)1, the interpolation is:
y(x) = y0 + (x-x0) * (y1-y0) / (x1-x0)
For the region (x,y)1 to (x,y)2, the interpolation is:
y(x) = y1 + (x-x1) * (y2-y1) / (x2-x1)
and so on. If you plug in x1 into both of the above functions, you'll see that you get y1 out, as expected for a concatenation.
steveastrouk
steveastrouk
Answer 7 years ago
AKA Piece-wise linear approximation ?
kelseymh
kelseymh
Answer 7 years ago
Yes, but I was trying to use the same terminology as the OP. With N points, a cubic spline would give a much better approximation, unless the original curve was already mostly linear.
steveastrouk
steveastrouk
Answer 7 years ago
Got to reckon P-WLA makes more sense than "concantenation of linear interpolants"...
