253Views6Replies
Author Options:
How to connect 10W led + 12v Led Driver directly onto Arduino? Answered
Hello there, can anyone give me an advice on connecting an 10W led + 12 volt drive to an Arduino Uno? it works but when i tried to connect to Uno it doesn't work anymore. Thankyou
steveastrouk
steveastrouk
3 years ago
Yes, without care, don't.
How did you wire it all up ? Can you post a diagram ?
NO pin on an Arduino output will accept 12V.
YuT6
YuT6
Answer 3 years ago
Hi Steve, I did it exactly the same as this video:
https://www.youtube.com/watch?v=WsGKk24h6Wo&t=635s
and i pluged the led driver into Gnd pin and Pin 9 on the Arduino...
thankyou
steveastrouk
steveastrouk
Answer 3 years ago
Does the LED work if you connect it, on its OWN to a 12V supply ?
If it does, you need to make a circuit, like Rick says, which will drive it with a 12V supply AND a pin on your Uno.
YuT6
YuT6
3 years ago
I used this product with 12v driver:
http://www.ebay.com/itm/331653946252?_trksid=p2057872.m2749.l2649&var=540791276944&ssPageName=STRK%3AMEBIDX%3AIT
rickharris
rickharris
3 years ago
your uno will only supply 20mA current. Not enough to drive the 10 watt led. You need to control a relay or power FET to act as a switch for a separate power supply for the LED friverrt. Look up uno interface ccts.
YuT6
YuT6
Answer 3 years ago
Hi Rick, thankyou for your help. :-)
