7252Views12Replies
Author Options:
How to control a servo with a switch? Answered
As above i was wondering how to fully turn a servo and turn it back just with a switch
It's for a dashboard sat nav box that flips up (Might add it on here)
Thanks
Gumby79
Gumby79
1 year ago
1.Take an RC servo of the correct power.
2 open the case snip the reastat wire.
3 add a rheostat find the values at the two positions you desire.
4 DPDT AB switch
position 1 /open.
A resistor Bridges 1 + 2 adding that ohm value to the servos internal . The servo will think it is centering comming to rest at the preset from step 3
3 is from servo 4 is to servo
5 +6 gets a resistor matching position B
rickharris
rickharris
8 years ago
In view of what your making you might find smart grease an interesting product.
http://www.rapidonline.com/Education/Smart-Grease-Starter-Pack-06-1294/?sid=b98d656b-8c92-423a-9a67-cf36d8a388d3
Jayefuu
Jayefuu
8 years ago
Here's another diagram (click to enlarge) in case Rick's is hard to follow. DPDT = dual pole, dual throw. They're fairly common. LS1 and LS2 are limit switches. These will need to be incorporated into the mechanical design of your unit. They will be activated when the box opens and closes to stop the motor, they're just SPDT or SPST.
If you wanted it so that you had 3 switch positions: open, close and stop you could get rid of the limit switches if you wanted and just put the switch back to the middle when it was opened or closed enough. Let me know and I'll draw a diagram for that.
James
Jayefuu
Jayefuu
Answer 8 years ago
Here's an improved schematic for Frollard's suggestion 3. The limit switches have been turned around and connected so that the NO contacts will short the two motor terminals together, braking (not breaking ;) ) the motor so it doesn't overshoot. I think it's right, Steve or IcEng should be able to confirm.
James
steveastrouk
steveastrouk
Answer 8 years ago
Nope. Missing a couple of vital bits. Consider what happens when the motor HITS the limit switch..
Jayefuu
Jayefuu
Answer 8 years ago
Diodes across the limit switches?
frollard
frollard
8 years ago
Servos need a very precisely timed pulse train to get them to go to specific angles, you have 2 options to do this:
1) microcontroller that takes the switch input and converts it into the pulses required by the servo. Easy and can be cheap.
2) analog circuit that varies in frequency at the flip of a switch. Possible, but pain in the butt to get right.
A third option that ignores using a servo:
Use a DC gearmotor with 2 endstops, and a dpdt 'updown' switch. The updown switch will cause the motor to turn on and go to the end of its travel where it will have the circuit interrupted by a limit switch, then turn off.
steveastrouk
steveastrouk
Answer 8 years ago
Varies DUTY cycle, not frequency....
Me, I'd go for option 3....I may even have a circuit.....
Jayefuu
Jayefuu
Answer 8 years ago
+1 for option 3.
rickharris
rickharris
Answer 8 years ago
+1
Connect it like this The double pole double throw center off switch will allow yu a middle position that is motor off. Or you can use a second on off switch as DPDT Co are hard to find.
frollard
frollard
Answer 8 years ago
yeah, it's the useless box circuit, but instead of the top of the throw reversing the switch it just interrupts the OTHER side of the dpdt so it ends up bistable.
