225Views8Replies
Author Options:
How to control speed motor dc 0-5000rpm with Arduino? Answered
Hello,  please I need help to control the speed of a dc motor with, for ex, Arduino.
I need it to set the rotate speed of a device that we use in I+D at the Uni. The roate speed that we use is between 0 to 5000 rpm.
Any idea and help is more than welcome!!!!
iceng
iceng
5 years ago
How do you measure the shaft speed ?
What is the size of your motor (weight, voltage, peak current ) ?
Is it a motor with bearings ?
iceng
iceng
Answer 5 years ago
Hey I'm not testing you. I want to know how the TA does that measurment !
iceng
iceng
Answer 5 years ago
Answer that and I might find an easy way to accomplish your task or are a lurker only.
DerpS
DerpS
5 years ago
Just use PWM. The motor is probably higher current then an Arduino digital pin can supply, so you would have to use a single transistor (or MOSFET) or an H-Bridge. For an example of Arduino PWM output:
analogWrite(10, 255)
That code would send a 100% PWM output to pin 10, which would be controlling a transistor or H-Bridge, which in turn would be controlling power to the motor.
steveastrouk
steveastrouk
5 years ago
Use the servo library.
For university work, the rest has to be your efforts. Otherwise you are a cheat.
-max-
-max-
Answer 5 years ago
+1
-max-
-max-
5 years ago
With a motor controller.
rickharris
rickharris
5 years ago
What can you find out about PWM control?
How much actual research have you done?
