153Views9Replies
Author Options:
How to convert an air pump/vacuum into a two mode machine which can blow and suck? Answered
Hi, I'm trying to build a simple robot gripper under a budget using this idea http://makezine.com/projects/universal-robot-gripper/. So from what I understand I need a vacuum cleaner that can change into an air blower with a flip of switch using the same nozzle. Is there any cheap option where i can make something similar? I was thinking of buying a cheap car vacuum cleaner or a cheap air pump and reverse the mode by reversing the motor polarity. Will that work? Really need a quick answer for my project, please help. Thank you!
rickharris
rickharris
Best Answer 4 years ago
Electrically the vac will not swap suck for blow. You will need to do this mechanically by changing over the inlet and outlet.
How much pressure/vacuum do you need?
In my head I am thinking a simple pump like a bike pump may be a better solution.
KhayhenS
KhayhenS
Answer 4 years ago
I don think i need that high of a pressure since I wont be lifting heavy stuff in my project. How do I use the bicycle pump and can I control it electrically?
rickharris
rickharris
Answer 4 years ago
Use a linear actuator to operate the pump - If you use a standard bike pump for cheapness you will need to put another air washer on the ram to suck as well as pump as in diagram - lick to see full size.
You could use hydraulics to operate the pump but that will be more complex.
KhayhenS
KhayhenS
Answer 4 years ago
Thanks for the help will consider doing this
steveastrouk
steveastrouk
4 years ago
Yes, reversing it is an excellent idea.
rickharris
rickharris
Answer 4 years ago
Will standard car vac with an impeller suck and blow when the motor is reversed?
Yonatan24
Yonatan24
Answer 4 years ago
From my experiments, with 2 small vacuum cleaners, no.
I don't remember hearing, seeing, or feeling a difference in the suction at all.
rickharris
rickharris
Answer 4 years ago
That's what I would expect, an impeller type car vac is moving air by centrifugal force (ouch). reversing it isn't making a lot of difference
KhayhenS
KhayhenS
Answer 4 years ago
What about an air pump for an aquarium? Is there any air pumps that don't use centrifugal force?
rickharris
rickharris
Answer 4 years ago
Most are diaphragm pumps not reversible
B
