19968Views15Replies
Author Options:
How to find hot side from a peltier element? Answered
hi how to find hot side and cold side from a peltier element?
DDG-2
DDG-2
2 years ago
The thermistor resistance allows me to calculate the temp on the cold side (that's where the thermistor is located). Is there any way to calculate the temp of the hot side using the temp of the cold side. Thank you for any help.
steveastrouk
steveastrouk
8 years ago
Put power in,
note polarity, Red is positive, Black is negative.
Note which side gets hot,
note which side gets cold.
Write it down.
Job done.
Prasadkvvv
Prasadkvvv
Reply 2 years ago
Very simple on your way of teaching
rickharris
rickharris
Answer 8 years ago
Attach power place hand on device - Say ouch - You found the hot side.
PS is your hand is stuck you found the cold side.
AngelAscanio
AngelAscanio
Answer 8 years ago
I understand steveastrok. If you buy a peltier cell and then you apply voltage without using heat disipators, BOTH SIDES GET WARM/HOT quickly, so you can't tell which is the hot side.
Honesttly frollard, ironic comments doesn't help in this community.
steveastrouk
steveastrouk
Answer 8 years ago
No, not if you are careful, and quick.
I have used Peltier cells in scientific applications for 25 years or more,
iceng
iceng
Answer 5 years ago
+1
iceng
iceng
Answer 5 years ago
Levity in science is like a wave riding a gigacycle in a magnetic field.
rickharris
rickharris
Answer 8 years ago
As far as I know the cell gets warm on one side and cooler on the other with an efficiency of around 5 - 10%.
You shouldn't need to heat sink the cooling side to get it to work.
http://en.wikipedia.org/wiki/Thermoelectric_cooling
steveastrouk
steveastrouk
Answer 8 years ago
Oops missed that stage..
frollard
frollard
Answer 8 years ago
I like it...it's like the weather reporting rope.
rickharris
rickharris
Answer 8 years ago
Got one of those it's 100 correct! More than you can say for the weather Office
sandy.12345
sandy.12345
Answer 8 years ago
when applying voltage to the peltier it should be attached with the heat sink otherwise it will be damaged
PaulA128
PaulA128
5 years ago
The vast majority of TECs have an ID printed on their heated side.
