138Views14Replies
Author Options:
How to generate power from water? Answered
Hi.Some days ago I was thinking about power in the future and how we can generate it from resources like sea water(that contains solt!).Can any one help me to know more about this to improve my ideas?
Tags:Power
rickharris
1 year ago
you can extract energy from the temperature difference between the surface and deeper water. You can extract energy from water movement.
Can you explain more about generating power from temperature difference?I think it is not enough!
https://www.youtube.com/results?search_query=generating+electricity+from+deep+ocean+tyhermal+difference
bwrussell
1 year ago
seandogue already covered the most of the type projects going on right now (wave generation, tidal or current generation). I think there is also some of these projects that also add solar or wind on top of platforms.
I'm not sure what you can do with salt water specifically that would have any sort of efficiency but if you shared some of your ideas that might help.
Hi.Thanks for your reply.I want to generate power from chemical experiments on soot water.like Osmosis experiments.
steveastroukbwrussell
Answer 1 year ago
You can extract energy from the INTERFACE between salt and fresh waters - say at river mouths.
charliel39
1 year ago
well
you can make hydrogen genarator and convert hydrogen to energy
seandogue
1 year ago
in terms of using the seas, there are devices that generate electricity from the motion of the waves (using some sort of paddle type arrangement to drive a generator) , and afaik, even turbines that work off tidal motion in estuaries. It might help if you posted your ideas. Can't comment on something we can't evaluate.
Hi.Thanks for your answer.I want to generate power from chemical experiments on solt water.Generating power from sea waves is not in my subject:-)
iceng
1 year ago
Sure, if you can separate electrons from one side of an osmosis membrane to another then in theory you will have a potential difference that can push current around and do useful work...
steveastroukiceng
Answer 1 year ago
Yes, I think I've seen a potential (sorry, no pun intended) idea for exactly what you've said, brackish water, membrane = volts
