106762Views14Replies
Author Options:
How to get In-ear headphones from slipping out.? Answered
I have a pair of Skullcandy headphones. They used to stay in my ears when pulled on, and just when wearing them. Now they always fall out. When I'm sitting or standing up, All the time. When I Absolutely needed to use them I would wear some kind of stretchy, over the ears hat. But I don't like wearing the hats all the time. Is there a way I can fix this without getting some new tips?
sshuggi
sshuggi
Best Answer 9 years ago
A couple of solutions:
1. Put them in upside-down so the wire goes above and not below your tragus. Then, wrap the wires around the backside of you ear. This works for me when I go jogging and sweat makes it slip out.
2. Flip the parabolic earpiece outfacing. Then, wrap the flat part with a thin bit of tape and flip the earpiece back in and see if it fits better. (Adjust the number of layers of tape to best fit.)
Sid.
Sid.
Answer 6 years ago
thanks man, having it upside down really helped! Have a great day :)
thilakas899
thilakas899
2 years ago
this item purchased but it not fitting corretly other sizes but waste of time fix it
RobinT24
RobinT24
5 years ago
i used shampoo and a sponge rubbed then thoroughly and now they are staying in my ear
ChrisW126
ChrisW126
5 years ago
Take the rubber ends off and put them back on in reverse, solved my problem entirely! Depending on how active you are at the time they can still fall out. Hope that helps :)
unominame
unominame
Answer 5 years ago
I honestly forgot that I used this site, up until I received an e-mail saying that I had a new answer to a question that I asked four years ago.
Those earbuds in the picture I posted back when I was 14, are long dead and gone. I killed them plugging them into a desktop headphone amp that was designed to drive headphones with a much, much higher impedance than what these could handle. In short, worked for four seconds, killed the driver, poof, they let smoke out.
T0BY
T0BY
7 years ago
I've developed a kit to make molded earphones from a kit. They don't hurt or fall out like standard earphones and they are also antibacterial so they prevent ear infections. You can get them here on my website.  Let me know what you think.
bwrussell
bwrussell
9 years ago
Sugru!
You need this stuff in your life anyways so know is the perfect excuse to buy some.
Apply sugru to earbud, wet ear with soapy water, insert earbud into ear, form, remove and leave for 24 hours.
thegeeke
thegeeke
9 years ago
Gaff tape would probably hold them in there... or duct tape (if you don't care about how painful it is to take off), or maybe even super glue! ;)
iceng
iceng
9 years ago
One other thought, try using a Q-tip with alcohol or Swim-ear to change
your skin friction to the ear-buds ? !
onrust
onrust
9 years ago
If you got them new, they came with different size rubber ends. I'd say you need the next larger size.
unominame
unominame
Answer 9 years ago
Yes I have the next size up, but they are too big. Maybe I should consider some custom order tips.
onrust
onrust
Answer 9 years ago
WAIT!!! Wrap some Teflon tape around the earbud and then put the rubber back on........ That will swell it up a bit
onrust
onrust
Answer 9 years ago
You could try getting some to fit from another pair/brand. Try a few different $.99 stores. They usually have a few different kinds.
iceng
iceng
9 years ago
I found paying more for them helped them stay in during down hill slalom skiing.
unominame
unominame
Answer 9 years ago
Thanks for the Constructive comment, Mr.Iceng.
I did buy these when they were somewhat new. at around 60$.
I like them. And the price bar for me is about 90$.
