2547Views3Replies
How to get rid of decimals or add them?
So here's my code.
void loop()
int pot = analogRead(A0);
float xval = pot * (10.0 / 1023.0);
Serial.println(xval);
When I open up serial monitor, I get a number (1-10 depending on my potentiometer) and two decimals. How do I make go in whole number increments? 1, 2, 3, etc? Can you show me the code and explain it?
Also, here's another example
centimeters = (xval * 2.54);
Serial.print(centimeters);
In this example, I only get a whole number. Can somebody show me some code to make it show decimals? Explain some code?
Thanks!
Best Answer 8 years ago
xval is a float data type which has a floating decimal point. If you want whole values only you need to use and int type.
In the second version you probably initiated xval as an int.
Answer 8 years ago
Oh bwrussel thanks so much! It just hit me!
So if I type in
float xval = ... then it will be a decimal
If I type in
int xval = . . . then it will be a whole number.
And yes, in my other project, I did put initiate them in the beginning of the sketch. Thank you so much!
8 years ago
Use the "printf" statement to adjust the format, and "ceil" and "floor" to clip the number to an integer.
