4758Views7Replies
Author Options:
How to get spraypaint smell out of a mask?? Answered
I am making a plague doctor mask for a halloween costume.  In a perfect world, I would have used leather or something similar, but that was not an option. SO, I made one out of fabric and heat 'n' bond.   After that, I painted it with spray paint, and now i can't wear it due to the smell! does anyone know how to fix this???? My nose goes in the beak, so it is unbearable.
NOODLE!
4 years ago
OOKAY THANK YOU :)
Triclaw
4 years ago
if you have to wear it now fill the nose with posies like the did with the plague :)
Triclaw
4 years ago
Time just got to wait. fan or blow dry it a few time to speed things up but time is your answer.
petercd
4 years ago
bicarbonate of soda in a saucer is sposed to remove bad smells from inside a fridge, so try putting a tablespoon full in the nose and maybe it will absorb most of the pong.
I had the same problem with the varnish smell from a pallet headboard, had to leave it in the garage for 3 days, didnt think of trying soda bicarb back then so I dont know if it will work.
Burf
4 years ago
A blow dryer on a warm setting will speed the paint curing but even that could take hours, perhaps even a day or more for the paint to cure depending on how heavy the coat of paint is.
Vyger
4 years ago
If its warm enough where you live you might want to leave it outside, maybe on a clothes line. The sun and the moving air will cure it faster. But it is still going to take a while.
mpilchfamily
4 years ago
The smell will persist until the paint is fully cured. You'll just have to keep it in a well ventilated area and wait. If you did heavy coats giving it little time to sit between coats this will take longer to cure.
