1002Views5Replies
How to increase amperage of a 5volt's current?
Hello,
I want to make a circuit which increases the amperage of a 5 volts coming out of a battery the voltage may decrease but the ampearage should be high or increased! Thank's for helping
Samad Haque
8 years ago
The best way of solving your problem is to solder battery pack from RC models cells. They have really huge amperage.
Answer 8 years ago
what are RC models cells and should i need to connect them in parallel??
8 years ago
In that case you need a step DOWN power supply. How much current ? What source ?
Answer 8 years ago
He is using a battery as a source. Makes things difficult.
I suppose as DDevilPL says you could put more cells of the same voltage (5 volts) in parallel with what you have which will increase the current available.
8 years ago
Total electrical power - WATTS - is a combination of Voltage and Current.
In the case of a battery the voltage and current are a matte os the physical construction of the battery and not changeable.
