1582Views5Replies
How to increase computer output volume without headphone?
I use p5-qplam motherboard.when i connect my 100mw 32ohm headphone,I feel its volume is very low even every volume adjuster is at max.
I don,t want to spend too much.How can I obtain more volume?
Best Answer 8 years ago
Where are you connecting the headphones? Are they plugged into the back panel or into a headphone connection on your case that is connected to the front panel header on the motherboard?
The audio output connections on the back of the motherboard have no pre-amp. They are meant to be used by speakers with there own amp. The front panel audio connector head on the board has a pre-amp so you can get good audio from a set of headphones.
Answer 8 years ago
so thats why it works in others computer well as my one does't have one infront
8 years ago
Add in a sound card. Even the cheapest cards usually have half or a full amp of power. Usually MUCH more power than you need in a small room. You should be able to get one for less than $15.
8 years ago
I think the easiest thing to do would be to obtain a set of amplified speakers, of the kind intended for use with a personal computer.
In my country, the former US, a set of speakers like this costs about 10 USD new. For example:
http://www.geeks.com/products.asp?cat=SPK
Also I have seen speakers like this on the used market, e.g. in thrift stores, for much lower prices.
8 years ago
external amplifier
An LM386 isn't too costly although not Hifi There are lots of other options.
