278Views8Replies
Author Options:
How to join metal to metal to create a T shape, no welding, no soldering? Answered
Hi, i've been working on a spring loaded arm mechanism and ran into a problem. i need to join metal(1mm thick) onto another sheet in a sort of T shape. Gorilla glue brand epoxy has failed me. Any suggestions?
normj
normj
9 years ago
You can use JB Weld epoxy. It can be purchased from Home Depot or Lowes.
Vyger
Vyger
9 years ago
To fasten it mechanically the sturdiest way would be to use a type of angle iron. Take a small strip of metal and bend it in the middle to 90 degrees. Then make a second one. Put one on each side of the upright piece and the two legs on the crosspiece. Then fasten it all together with screws or rivets. You can clamp it in place with vise grips while you drill it.
Burf
Burf
9 years ago
Pop rivets
sheet metal screws
screws and nuts
spot welder
Re-design
Re-design
Answer 9 years ago
My guess also.
