3450Views6Replies
Author Options:
How to limit DC current without affecting Voltage? Answered
I would like to be able to choke current example 12-20amps from the 40amp peak to peak keeping voltage level to rise when the current begins to fall again as stabling after a huge load peak. This will preserve energy consumption on my circuit.
Things ive researched
Transformer choke
Current limit thorough chips
add a pwm and control (expensive and time consuming)
ArturoC6
ArturoC6
5 years ago
Well i have a motor that pulls a constant amperage and runs at 12v. The motor goes up and down in rpm dependent on load. Since a drop in rpm will not hurt the system. Id like to have a way to control current to not overheat the dc motors. Does having a h bridge with pwm help control heat i was thinking with a arduino.
steveastrouk
steveastrouk
Answer 5 years ago
You're trying to beat physics, and you can't. A DC motor draws a variable current depending on its load, to draw that current, the RPM changes.
rickharris
rickharris
Answer 5 years ago
+1 Fixing the current will just cause the motor to drop more RPM under load - or to look at it another way it will limit the output of the motor.
As I said originally you need to be MUCH more specific in your project requirements to allow us to asses what you can or an not do.
Downunder35m
Downunder35m
5 years ago
I think you did not understand the basics of electrics.
And I don't even try to explain things as there is not enough from your end to go with.
iceng
iceng
5 years ago
It seems you do not have experience with DC power supplies.
If you have a [stiff = low impedance] DC power supply then it makes no difference if the current is full-flow, half-flow or not-flowing and the voltage will be constant = the same.
To adjust the current flow you will need a power mosfet and the electronics to control it. Weather you go analog or PWM depends on over 3 semesters of education and the load requirements you have not even mentioned.
rickharris
rickharris
5 years ago
Yet again we need to know a lot more about what your trying to achieve.
https://www.google.co.uk/search?q=constant+current...
will give you a constant current.
In general a circuit will draw the current it need to operate - or as much as it can depending on the type of circuit.
Power is a product of current and voltage - I x V=W
For a given voltage you will use a given wattage if the current if fixed. however your circuit may not operate as you think if you limit the current. (depends on what it is)
