414Views5Replies
Author Options:
How to machine an o-ring gland in the corner? Answered
There is a gland in the corner on the right picture (piston o-ring gland, static work). What are disadvantages compared to design on the left? Do I have to machine a rounding in that specific case, when groove is situated next to the wall (marked with red circle) to avoid extrusion? Do I need to machine a clearance above this rounding?
Blue arrow simulates constant pressure of 1 MPa (150 psi) only from one side.
steveastrouk
steveastrouk
Best Answer 8 years ago
THAT O ring ain't ever going to extrude from the groove you've shown. Do you have proper design refs for O ring seals in static cases ?
How is the compression on the seal being applied, in both cases ?
DDevilPL
DDevilPL
Answer 8 years ago
That is only an example picture. I do have a table of sizes for o-ring gland in case of desing on the left. The most important question:
Do I need to machine a clearance above this rounding marked with red circle?
steveastrouk
steveastrouk
Answer 8 years ago
Like I said, how is the compression being applied ? The LEFT design is stronger, if the load is applied at the centre, the right design is stronger if the load is applied over the O ring.
Why SHOULD you need a clearance over the fillet ? Answer: you don't.
Steve
iceng
iceng
8 years ago
Which way is pressure applied ?
What is the arrow signify ?
A
DDevilPL
DDevilPL
Answer 8 years ago
Constant compressed air pressure of 150 psi (blue arrow).
