9861Views13Replies
Author Options:
How to make a cigarette smoke detector Answered
I have searched for a cigarette smoke detector circuit. But  can't find one. I need it for my research project.. Pls. help me.thanks! :)
vijayP10
vijayP10
5 years ago
what are component need to make a cigarette smoke detector for car.. please help me.. thank you..
iceng
iceng
9 years ago
A low cost pulsed laser that draws air through the the beam with an LDR behind the laser feeding a simple AC amplifier will detect smoke particles and if you have it dust...
A
iceng
iceng
Answer 9 years ago
Detail smoke sensor pics 4 U...
Bot1398
Bot1398
Answer 9 years ago
The cigarette smoke contains carbon monoxide so you will need a carbon monoxide sensor.You can can buy it from sparkfun.com.Also checkout the wiring example.Experiment with the sensor get the readings using a arduino or any microcontroller and make one yourself
Bot1398
Bot1398
9 years ago
flxforce
flxforce
9 years ago
You want to make yourself ? It' s difficult ,the plastic and many others kinds of parts.
rickharris
rickharris
9 years ago
The airlines use normal smoke detectors which use the ionisation properties of smoke to set off the detector.
lemonie
lemonie
Answer 9 years ago
I thought the blocked a current of alpha-particles: Americium 241
L
orksecurity
orksecurity
9 years ago
The question is, how dilute can the smoke you want to detect be?
If sufficiently dense to be seen, the old optical detector approach would work.
If less dense, a commercial smoke detector may be your best best.
If _very_ thin -- if at a level which wouldn't set off a fire-safety smoke detector.-- you're into lab equipment with costs to match.
Kryptonite
Kryptonite
9 years ago
Smoke detectors are very hard to make as they normally contain radioactive materials, which are not really safe to handle. Cigarette smoke sets off standard smoke alarms, which should help you with your project.
lemonie
lemonie
9 years ago
As different to any other kind of smoke?
L
