27883Views8Replies
Author Options:
How to make a hole on a seashell? Answered
Does anyone know how to make holes on seashells without using a drill? Please let me know if you do.
Muchtested
Muchtested
5 years ago
If you have the patience, a small very sharp scissor blade should work.
cerberustugowar
cerberustugowar
6 years ago
you may also be interested in getting a diamond impregnated bit. I've used them to drill holes through stone and it would easily go through a shell. Here is a picture http://upload.wikimedia.org/wikipedia/commons/e/e3/2mm_diamond_drill_bits_macro.jpg
steveastrouk
steveastrouk
6 years ago
You can rub a hole through with sand and a stick, spinning the stick between your hands, and pressing sand between the stick and the shell.
Muhaiminah Faiz
Muhaiminah Faiz
Answer 6 years ago
Sounds effective, I'll give it a try. Thanks!
petercd
petercd
6 years ago
+1 for the hand drill.
I doubt very much that a dentist will
give you used drill bits, they would be considered hazardous waste
seeing as they come into contact with the patients blood.
Better idea is a small masonry drill bit from the hardware store, however the smallest is 3mm dia which might be too big for your needs.
Vyger
Vyger
6 years ago
Well, I would suggest that you really do get a drill, not a power one but a simple hand power drill. Since you appear to do a lot of crafting work it would probably come in very handy AND they are not very expensive and last forever. I have one my grandfather used. it never needed anything except a little oil.
Next get a used dental bit from your local dentist. They are carbide burrs and can cut through glass so a shell would be very easy even if the bit is dull. I am guessing the dentist usually throws them away so they would probably be free for the asking.
I have a friend who used to repair car windshields from cracks and chips. he used a hand drill with a dental bit to drill into the cracks and then injected a special glue. So its something that should work for you.
rickharris
rickharris
6 years ago
A sharp pointed knife will penetrate the shell - Mind your fingers.
