219Views13Replies
Author Options:
How to make a small 3x3x3 led cube? Answered
Hey I want to make a small 3x3x3 led cube for placing in my desk. I see some of charliplexed cube but they are difficult to understand. So pls hlp me. I want a small cube run by cheap small micro-controller like attiny. Pls give me detailed circuit and code to run.
Thanks in advance
Soumojit
Soumojit
Answer 3 years ago
I cant creat too much patterns cause their is no microcontroller
rickharris
rickharris
Answer 3 years ago
And there you see the problem of not having a microprocessor. You CAN change the pattern by resoldering the connections but not easily, That is how it works.
You want varying patterns, use a microprocessor, You are happy with a reduced performance use the 555.
Soumojit
Soumojit
Answer 3 years ago
I want to use a microprocessor, i see some cube with pic controllers bur I dont know any thing about pic or how to program them
rickharris
rickharris
Answer 3 years ago
You have changed the question - OK
Google STILL tells you what you want to know.
https://www.google.co.uk/search?q=Code+for+3+x+3+c...
including code samples BUT if you have NO skill in this area you will spend you time better trying to do much smaller things first, light a single LED, flash it on and off, light several, workout charliplexing, try to do it with 3 LEDs
THEn you might be able to get your cube working.
NO before you ask it is doubtful if anyone here will write the code for you.
https://www.instructables.com/howto/3+x+3+cube/
https://www.instructables.com/id/Lets-Program-a-PI...
https://www.instructables.com/howto/charlieplexing...
If you can't do what you want from the information given then your not likely to be able to do it until you learn more.
iceng
iceng
3 years ago
Strange, you do not show an ible about the 3^3 cube you say you made !
Also strange, you do not want to use a uP !!
Very strange, you ask for help with detailed micro-controller code !!!
Unbelievably strange, you want to use several tiny ICs to make it super attiny ??
I wait for when your desires are not in conflict with every statement you make,
please make it clear...
Soumojit
Soumojit
Answer 3 years ago
I want to make a charliplexd led cube so it use less io pins
steveastrouk
steveastrouk
3 years ago
Plenty of instructables here on the right >>>>>>>>
Have you tried them all yet ?
Soumojit
Soumojit
Answer 3 years ago
Most of them uses the arduin. I need that will small in size and use small ics. I have seen those pic ones they are small but i font know about pic microcontroller. I see some charliplexed led cubes but their is no code
Kiteman
Kiteman
Answer 3 years ago
There are small versions of the Arduino.
Soumojit
Soumojit
Answer 3 years ago
I know but I want to make it with small ics like attiny
steveastrouk
steveastrouk
Answer 3 years ago
"Arduino" is software on a chip, you can put your Arduino code on a surface mount Atmega chip, or just buy a Nano. There are a bunch of charlieplexing libraries which hide a lot of the pretty scary amount of I/O handling needed from you.
if you don't want to charlie plex, you'll have to multiplex on 3 x 9 pins, so you need 12 free digital pins. Remember that there are significant current limits on the pins, but if you make a high efficiency red led cube you can get down to decent levels of light with 1mA through your LED
Soumojit
Soumojit
Answer 3 years ago
I made a 3x3x3 cube using multiplexing. I want to make it small and want to use charliplexing. I find a 3x3x3 cube using charliplexing and an Atting 13. But I cant find how to connect the cube with the ic. I also see some cube with attiny 2313 also......... I want to make it super small
