169Views4Replies
How to make a small ground?
I want to make a lightsaber from a 18w neon tube. I am using a 12v to 1800v inverter. The positive lead is connected at the bottom of the tube but in need a ground on the top without pulling a wire from the inverter.
Best Answer 9 years ago
. You may be able to get away with using your body as the "ground", but that can be dangerous if your body becomes grounded.
. For your application, I'd try running a very light gauge, varnish-insulated wire (more or less invisible when the tube is lit) down the side of the sword to the handle and make the connection(s) inside the handle.
Answer 9 years ago
if just the is connected it gives me a little light
I touched the negative lead and the glass of the tube and it lit up
but i will use a barely visible wire
9 years ago
If you wear rubber-boots and don't touch anything enough voltage will cause leakage through the air...
L
9 years ago
Is it really a neon tube or a florescent tube?
You have to make the connection. It doesn't draw much current so you should be able to run a very small wire to the connection that wouldn't be noticed.
On the other hand, at some ungodly voltage the neon tube will glow without any connection.
