2217Views5Replies
Author Options:
How to make a solar-powered garden fountain low maintenance by adding a float valve? Answered
I have a solar-powered garden fountain that I wish to make very low maintenance and not have to manually fill with water. How could I install a float valve setup in the fountain? Has anyone ever done this? Any ideas?
frollard
frollard
Best Answer 11 years ago
if you have a fresh water supply, there are float valves for use in humidifers that are pretty low footprint, and would fit in a fountain nicely.
arnold54
arnold54
Answer 11 years ago
Thank you for the info. I'm assuming humidifier float valves are small in size? How do I determine which float size to use for my fountain?
frollard
frollard
Answer 11 years ago
they only ever trickle, and open tiny amounts at a time. If you have a humidifier on your forced air furnace, check it out - works like a toilet float valve, but the toilet valve is high flow - the humidifier one is really a lot smaller, and takes 1/4 inch input pipe.
arnold54
arnold54
Answer 11 years ago
I don't have a humidifier, but will do an online search for a float valve I can use to hook up to my water supply. Thanks for all of your input.
frollard
frollard
Answer 11 years ago
You're welcome - check hardware stores (like home depot, lowes, rona, etc) and they should be able to source 'replacement' valves easily and relatively cheap. If this help - please mark answered!
