53730Views12Replies
Author Options:
How to make a wick for an oil lamp? Answered
Does anyone know how to make a wick for an oil lamp??
I don't really know how the wick works, so I don't have ANY clue on how one would make it.
Any help would be greatly appreciated!
IngerulM
IngerulM
5 years ago
I have used cotton rolled between my palms until the desired thickness is achieved. But,I found the cotton burns a rose on the end like regular candle wicks.SO,I tried jute cord. It's a natural fiber from plants,and it lasts longer than cotton and required much less maintenance .NOW...I use these wicks for an oil lamp I made and I use olive oil.Olive oil is great in my opinion,since it isnt as flammable as regular petroleum oils,and doesnt create the flammable vapors that can be found in petroleum oils.AND it burns just as bright. If my lamp tips over,the flame is drowned out and LITTLE to no risk of fire is a plus.But for me,again,jute cord is better than cotton.But I guess that would also be up to the user and the design of the lamp.BY THE WAY... I tried vegetable oil as a lamp oil,and unless you want your room to smell like pop corn,I'd stay away from it.olive oil burns with no smell.And mineral oil burns well also,but it burns sooty.If you watch just above the flame tip,you'll see a stream of black,sooty smoke from the flame. So...with the various oils I have used,OLIVE OIL is the way to go,and jute as the wick is the best.
Dale Hueske
Dale Hueske
5 years ago
You have some GREAT Stuff on this Website !!!!
rickharris
rickharris
7 years ago
Essentially the wick doesn't burn - it acts as a pathway for the fuel which when it reaches the hot end of the wick vaporises. It is this vapour that burns.
in practice the wick will slowly char at the tip and get shorter requiring trimming to get a clean flame.
A thick cotton string is ideal. you can braid some thinner strings together if you can find anything thick enough.
Most good old hardware stores should be able to sell you one though. Or a garden centre where they are used in green house heaters.
DIY9393
DIY9393
Answer 7 years ago
How about a wax like wick from like a candle?
mpilchfamily
mpilchfamily
7 years ago
You need to use a natural fiber to make the wick braid. Cotton is the typical material used. The wick draws in the oil and feeds it to the flame. The idea is that the flame burns the oil not the wick but the wick does eventually burn a bit. The larger the wick the brighter the light and the faster you burn through the oil.
seawee65
seawee65
Answer 7 years ago
So... would a piece of cloth do?
DIY9393
DIY9393
Answer 7 years ago
Yes, but I would do something cotton fiber based.
Josehf Murchison
Josehf Murchison
Answer 7 years ago
yes cotton blue jeans work well
Joe
DIY9393
DIY9393
7 years ago
Anything that would do well under heat, but i would use a cotton based material. :)
DIY9393
DIY9393
Answer 7 years ago
I have many oil wick lamps and they look like cotton fiber braids...
Maybe, if you do not what to use cotton fiber, use wax wick, like for a candle? But not sure if it could work...
I hope this helps you.
Vyger
Vyger
7 years ago
A material you can't use is anything that melts under high heat. Polyester and nylon or blends with them would melt and would not work. That is why cotton is used most of the time. Silk is often used for gas light mantels, but that is actually the ash and not the silk itself. I believe at one time they used to use asbestos with cotton but now we know that is pretty bad. In medieval times they made table cloths out of asbestos and to clean them they just put them in the fire to burn anything off of them but they also had pretty short lifespans from other things like the plague.
