700Views22Replies
Author Options:
How to make amplifier using (2) LM4440 ic maybe bridge ! Answered
Hello , i have a circuit board, having all element,
I want to make a good amplifier using 2  lm4440  ic, as given in the images,
Please help me to find music input connection, speaker output and dc input,+ -
And also tell me is this best for high bass,
Please find all circuit diagram,
iceng
iceng
3 years ago
I cannot help people vvho are blind !
MannuH
MannuH
Reply 3 years ago
then go to H..
iceng
iceng
Reply 3 years ago
Wow.... Mannu the demon telling me where to go...
Did you ever click the picture and have a sighted person compare it to the original circuit ???
MannuH
MannuH
Reply 3 years ago
thx for respect, but i didnt found ic pin (leg) no.4 and 8 in ur image, as my ic have total 14 pins, and if u dont want ro help mine then simply say sorry, thx again for respect( i m demon )
iceng
iceng
Reply 3 years ago
When a pin on a 14 pin IC1 is not shown it is a you understood no_connection...
MannuH
MannuH
Reply 3 years ago
this is the thing u need to mention first, because i didnt know it first,
At last , can u tell me where is c1 in diagram to increase value,
And tell me voltage and uF of capacitor , that need to replace to increase bass. And sorry again i m demon fknn begineer, so, i'll take time to understand
Downunder35m
Downunder35m
Reply 3 years ago
If you lack or vital and bsic skills to build this circuit then it would be wise and logical to start with something smaller.
Get a ready to solder kit or something to work on breadboards and learn from there.
Sorry to say but what would be the point if we explain it all but you have no clue how to check your results or at least understand what the circuit is doing.
Get some ready to go amps and make musik with them and while listening to it do some easier stuff first ;)
Before we landed on the moon we learned how to fly ;)
MannuH
MannuH
Reply 3 years ago
i m not doing this for fkin learing.. I have this board and i only want to make amplifier, not fkn doing soldering, i better know, btw i m asking to iceng ,not to u, ok !!! Moon monn etc etx..
Downunder35m
Downunder35m
Reply 3 years ago
Watch your language dude, your attitude stinks to say it nice.
You want help but refuse good advise and give insults instead.
Go ahead and do your thing your way but don't expect anyone here to help you more than what we already did ;)
MannuH
MannuH
Reply 3 years ago
I thought u leave anger in the past year, but it seems, still little bit u have,
Downunder35m
Downunder35m
Reply 3 years ago
It is not anger ;)
Look at your replies and what was done by other people to help you going.
If you not with the right tools and have no clue about car engines: Would you replace worn piston rings yourself or would you drop the car into a shop to get it fixed?
I understand your need to build you amp from what you have but without any knowledge or the tools to do so I fail to see it working out.
And despite leaving "u" and "g" you expressed yourself quite clearly.
Asking for respect also means respecting others, which I did not see in your replies.
Being direct and honest might offend you but would prefer someone spoon feeds you through something that might take weeks to finnish and never work?
iceng
iceng
Reply 3 years ago
+1
If OP does not solder then this is a fools errand because after cleaning that PCB there will be even more difficult desoldering and soldering without delaminating the conductor traces and you will see (the OP) get disappointed and agitated younger man who will plummet me all the way to the depth Hades ;-(
iceng
iceng
3 years ago
A single amplifier, increasing C1,C8,C9 by 20% will increase Bass response..
MannuH
MannuH
Reply 3 years ago
all done, but bass not good, and what u said abt c1,c8,c9, i didnt get anything abt this, i just wire input and output, help me to get bass boost
iceng
iceng
Reply 3 years ago
Click the pick to see all.
You do not have a published skill set (what you can do) ?
The increase of the selected capacitance by 20% means 0.1x0.20 => 0.02
The nearest value is .022uF example
iceng
iceng
3 years ago
Regrettably I see no circuit !
MannuH
MannuH
Reply 3 years ago
see now
iceng
iceng
Reply 3 years ago
This board has been Stepped On and submerged in DEEP DIRTY MUCK and even if I could make out 'READ the IC names' there is NO way to ID where copper traces run on the component side to answer your Question..
Downunder35m
Downunder35m
3 years ago
If you want to salvage and test the audio amp IC be my guest but I would not use the board.
No clue where you found it but it looks like it had a lot of abuse from the elements.
Even if you clean it there is no way of telling if that stuff will ever work again.
Downunder35m
Downunder35m
3 years ago
Well, no circuit but in any case the datasheet will answer your connectivity questions.
As for sound there is a reason why people use capacitors and inductivities to match the frequency range of their speakers.
If you are just after the big boom instead of natural sound you might want to consider using a seperate amp for a seperated bass speaker or subwoofer.
MannuH
MannuH
Reply 3 years ago
i forget to upload images
