18268Views6Replies
Author Options:
How to make lighted wine bottles without drilling? Answered
I don't have a glass drill bit, is there another way to install the lights in a wine bottle either using another type of drill bit or a way that I don't need to drill?
kevindeangelis
kevindeangelis
9 years ago
The Dremel Diamond bit has worked really well for me... I think I bought mine at Lowes for around $24 (with lubricant). You can also get pre-drilled bottles from www.LightUpBottles.com
rickharris
rickharris
9 years ago
try drilling under water with a cordless drill and a masonry bit.
Try drilling with grinding paste and a copper tube of the required diameter.
Try looking for a lamp holder that is made for bottles and does not require the bottle drilling.
http://www.amazon.co.uk/s/?ie=UTF8&keywords=bottle+lamp+holder&tag=googhydr-21&index=aps&hvadid=15928143228&ref=pd_sl_11txizztzu_e
for example from amazon.
iceng
iceng
9 years ago
Drop a throwie led into the bottle.
If you don't like only 3 days of light,
Go wireless Power and feed the power from outside the bottle
( Last Pic ).
A
Jack A Lopez
Jack A Lopez
9 years ago
Uh... Doesn't a wine bottle already have a hole in it? I mean the hole in the top with a cork stuck in it. You know, the hole through which the wine gets poured out. Can wires be routed in, and out, through that hole? Is the light-emitting component small enough to fit through the hole? Cannot a beam of light itself be directed into the bottle through this hole?
The Skinnerz
The Skinnerz
9 years ago
If they don't need to be accurate, you can carefully melt holes through with a gas torch, ensuring to try and keep the heat even and heat it slowly.
Alternatively, some sort of abrasive cutting disk should do the job if you are careful.
steveastrouk
steveastrouk
9 years ago
Try a diamond bit in a dremel type tool ?
