3664Views8Replies
Author Options:
How to make (or where to buy) spring loaded fins for a model rocket? Answered
I think it would look really cool if I could launch model rockets from some sort of tube or underground silo. The only problem is that the fins get in the way of securely packing the rocket in the tube. I would like to know if there are plans for spring loaded fins or if there is a place where I could buy a set of spring loaded fins.
Tags:rocket
Nicepolicy16
Nicepolicy16
Best Answer 11 years ago
Firing an RPG-7 The RPG operator or an artillary assistant takes a propelling charge (booster, in image below) and screws it onto the end of a warhead. Basically, this is a stabilizing pipe that has four stabilizing fins that are folded around it with two additional fins at its rear end. A cardboard container encases the back end of the stabilizing pipe. Inside the cardboard container, a squib of nitroglycerin powder is wrapped around the stabilizing pipe and a primer or charge of gunpowder is stuffed into the end of the stabilizing pipe. The RPG operator or artillary person then takes this assembled artillery and loads it into the front end of the RPG launcher so that it lines up with the trigger mechanism. After the RPG operator pulls the trigger, this is what happens: •A percussion cap ignites the primer, gases build up inside the launcher’s chamber, thereby breaking apart the cardboard container and propelling the grenade forward through the barrel of the launcher. In this way, the cardboard container is a lot like the casing containing the gunpowder on a bullet. •The force of the built-up gases throws the grenade out of the tube at approximately 384 feet per second (117 meters per second). The abrupt acceleration of the grenade leaving the launcher triggers a piezoelectric fuze that ignites the primer (pyro-retarding gunpowder mixture). This then ignites the squib of nitro, thereby activating the rocket propulsion system (sustainer motor) to carry the grenade the rest of its trajectory. •As the grenade leaves the launcher, the fins along the stabilizing pipe spread out, which, along with the rocket motor, allow the grenade to travel a long distance at a potential speed of about 965 feet per second (294 meters per second). The grenade moves like a football, rotating through the air; the fins stabilize its flight.
mkmehp
mkmehp
7 years ago
check the pic
dizzle976
dizzle976
11 years ago
do a google image search for the MLRS munitions. they have springloaded fins, and dont take up much room. i you make a  fin out of soda bottle or a similar flexible plastic, it defeats the point of having fins. they need to be rigid.
Nicepolicy16
Nicepolicy16
11 years ago
You can buy a Hydrogen Fuel Rocket that turns water into hydrogen from your model air craft shop . This rocket has fins that are folded . They are NOT spring loaded . The fins are not used for stability . The Fins are used as a Giro Copter instead of parachutes for Landing safely . Do not cost much and more powerful than puchased rocket motors .
rickharris
rickharris
11 years ago
Fins cut from soda bottles (PET) are flexible enough to fold flat and spring back when released.
thecookiemonster
thecookiemonster
11 years ago
why not just use flexiable fins that will pop out whenever the rocket leaves the tube? they would just pop out and would be more relaible then spring loaded ones!!!
lemonie
lemonie
11 years ago
I agree, but do you really need fins? You can't store them where the rocket motor is, which leaves you with having to put them in the wrong place. Difficult. L
