543Views1Replies
How to make pump for a waterfall ( height approx. 10cm) and water depth approx 2cm for an aquarium.
I have this aquarium 60x30x30 cm. I wish to setup a waterfall in the aquarium. Now the depth of water in the aquarium is to be approx. 2cm and the height of waterfall is to be approx 10cm.
I am looking for a pump design which could work comfortably in that water depth.
9 years ago
You need an impeller type pump - volume rather than pressure - a small motor with a flat bladed impeller on the shaft running at high RPM.
Put this inside a container with input/output pipe and your in business.
May be easier to buy from a scrap yard a wind screen washer pump and run it from a wall wart.
For other ideas go here
