539Views9Replies
Author Options:
How to operate a brushless motor (without complex systems)? {Sea Scooter Project} Answered
I'm trying to make a mini "sea doo" sea scooter for under 100usd.  Im wondering if its possible to run a brushless motor with a simple switch rather than a complex arduino based system.   I will probably enclose the project in a 4-6in diameter pvc pipe with end caps and run the propeller shaft through a smaller pipe with 2 bearings on both end to keep water out.  I would prefer to have a hand drill style switch for variable speeds but if that's not possible single speed button will work also.  Also are li-po batteries a good option for this.
rickharris
rickharris
Best Answer 3 years ago
Peter doesn't discuss the detail of his design but covers some of the pitfalls he found.
To run a BLDCM the easiest way is to use an RC ESC. This takes the battery and a control signal to give a variable speed signal to the motor and includes all the driver tech.
You can easily provide the speed signal from a servo tester (a few $).
Your option of a cordless drill also has the required electronics built in which may suit you.
steveastrouk
steveastrouk
Answer 3 years ago
Most cordless drills are still brushed motors though.
steveastrouk
steveastrouk
Answer 3 years ago
We have a BLDC Dewalt in the shop here, its incredible !
rickharris
rickharris
Answer 3 years ago
I took a look at my relatively cheap generic drill and impact driver bought recently and to my surprise they both claim to be BLDC motors.
i guess a lot of BLDCMs are being made now perhaps that's why they are so cheap on the RC hobby market.
iceng
iceng
3 years ago
There are low RPM variable speed handrills...
steveastrouk
steveastrouk
3 years ago
No, you really need some smarts to run a BLDC motor, it doesn't have to be an Arduino, but you do need more electronics than a switch.
TypeNameHere
TypeNameHere
3 years ago
...hopefully last question. In the original post I was hoping for a drill style pressure switch... Do you guys think i could just use an old thrift store drill with the propeller in the chuck lol. Seems a little too easy but hey if it works. Drills usually only go to about 1500 rpm but perhaps i could modify the gear box and take out a few gears sacrificing torque for rpm. From there i could power the drill using either the normal battery or a rc car battery.
TypeNameHere
TypeNameHere
3 years ago
Also how much thrust would be created in water by a say 5in diameter 3 blade propeller spining at about 3000-6000rpm. I looked online for a formula or something but was unable to find anything.
