305Views7Replies
Author Options:
How to pick out a transistor? What I should look for? Answered
I need a MOSFET transistor for a flyback transformer driver. Many guys said 2n3055 and I want another. How can I compare?or can you give me a list of transistors that I can use?
steveastrouk
steveastrouk
Best Answer 10 years ago
It depends on too many complex things to detail here. Start with maximum voltgage (Vds) or Vce rating, and speed. Mosfets are tricky to driver very fast, so a 3055 may be a good choice, coupled to its relatively low Vce (Sat)
theVader75
theVader75
Answer 10 years ago
can I use a 2n5020?(http://www.datasheetcatalog.org/datasheet/stmicroelectronics/9038.pdf)or a mj1000?I found this site and there are some transistors(http://www.angelfire.com/80s/sixmhz/flyback.html) or this transistor (http://www.datasheetcatalog.com/datasheets_pdf/2/N/3/7/2N3715.shtml)?
steveastrouk
steveastrouk
Answer 10 years ago
I don't know your supply voltage, I don't know your peak charging current, I don't know your driver stage....
theVader75
theVader75
Answer 10 years ago
My supply voltage is 22 and supply current is 16amps and the driver stage is 0 because I am gathering meterials. if you know a simpler driver please tell me ,I want the simplest and safest way. Thank you.
steveastrouk
steveastrouk
Answer 10 years ago
Given that Ic = 1.2 A, and Icmax is only 6A, then clearly the 5020 isn't going to work. You need a POWER transistor, and a fast switching one too. Steve
theVader75
theVader75
Answer 10 years ago
Ok, i forgot that i have a monitor pcb with all of the things on it including an new flyback transformer and lots of mosfet transistor but i dont know which to use.
steveastrouk
steveastrouk
Answer 10 years ago
If you've got that, I'd poke around and find the flyback circuit there. You'll learn a lot that way.
