17340Views13Replies
Author Options:
How to power an electromagnet? Answered
Is it better run an electromagnet of a bigger voltage(12V) with a smaller current(150mA) or with a smaller voltage 5V and a bigger current? Which will heat it up less? Does it even matter? The electromagnet will have to work for several hours so heat is my main problem. Also should I use thicker or thiner wire? I'm trying to build a electromagnet for a ferrofluid project.
iceng
iceng
Best Answer 9 years ago
So, im guessing you already made at least two magnet coils.
Which one to do you use ?
The coil with the most turns will have the ability for the largest magnetic Flux.
Flux  is a product of the number of turns and the current.
In fact you may find that you can reduce the current and still produce
the Flux necessary for your ible.
So the coil with the most turns has the best chance of operating cooler.
If you need more Flux you can add a NIB round ( same diameter as the bolt )  permanent magnet making the coil run cooler.  Then for no Flux reverse the
coil current ( still runs cool ).
A
iceng
iceng
Answer 9 years ago
Here is a cool magnetic solution.
Add a NIB magnet and now you get more Flux for the same current !
And if you need to Zero the Flux, Just a little Negative current.
Please enjoy the Pic.
A
avinashmech353
avinashmech353
7 years ago
how can i construct an electromagnet of power 1 to 2 tesla...?
Thanks in Advance.
odvratno.zgodan
odvratno.zgodan
9 years ago
Thanks everybody for their answers. I'll be experimenting with the number of turns and try to lower the current. My main problem is heat because the electromagnet will be running almost non-stop.
Now I see how I could have made a mistake by appending the image of the electromagnet made by winding wire around a bolt. I'm trying to make something like a door lock. So I'm trying to make it more of a rectangle(110mm X 15mm). Well actually I'm trying to make a 9-segment display that would use ferrofluids to display the time. So alltogether 4 displays, each 9 electromagnets. I'm still in the experimenting phase trying to figure out if it is feasible.
Anyway thanks again for all your answers. All of them have been wery helpfull but icengs answer of the use of NIB magnets was a total revelation to me.
kelseymh
kelseymh
9 years ago
The answers are all here, but it's not a simple problem with one answer. You are trying to optimize a system in several dimensions.
With a fixed diameter, seandogue has pointed out that your field strength (or "flux") scales with I×N, where N is the number of turns. So that argues for higher current.
Heat dissipation from resistance scales with the square of the current: P = I×V = I2R. That argues for lower current (which helps quadratically), or for lower resistance (which helps linearly).
Note that since P = IV, if you raise the voltage and lower the current, keeping the product constant, you will get exactly the same heat dissipation!
The resistivity (resistance per unit length) of wire scales inversely with cross-section. That argues for larger diameter wires, but that in turn means fewer turns (and hence lower flux) for a give spool.
So what you need to do is figure out what your real system constraints are, and optimize after all those constraints have been applied. For example, you can estimate the total cross-sectional area of wire that will fit in the spool, and use that to balance the maximum possible N vs. gauge (diameter). Once you've chosen the wire gauge, you can look up the resistivity, and use the spool dimensions to determine the total length. and hence resistance. And so on.
gkohle
gkohle
9 years ago
Also according to Ohm's law (V=IR), the smaller voltage with higher current will reduce the resistance. In my physic's class, we use d cells for powering electromagnets.
rickharris
rickharris
Answer 9 years ago
The resistance is fixed by the total resistance of the coil. So in Ohms law the r will be a fixed value
seandogue
seandogue
9 years ago
You will want to limit your current due to the gauge of wire used and heat generated by its natural "real" or "steady-state" resistance. The easiest way is to control your voltage with a variable voltage source. Start low.
Although I can't be sure, since the only frame of reference is the nut/bolt combination, it looks as though you've used something on the order of 30 or 40 gauge. As such, you'll need to be ~careful not to exceed its limits. (For instance, you probably don't want to try to pump a few amps through it)
The magnetic field is proportional to IbN, where Ib is the current through the solenoid, and N is the number of turns.
Measure the real resistance of the solenoid using a multimeter to get a baseline value, from which you can compute a ballpark voltage for a given input voltage
For future reference, Lower N, higher I will have a faster turn on time due to a lower inductive component to the solenoid.
If you don't have a variable voltage supply, consider getting hold of a rheostat, ie, a power potentiormeter, for varying the input voltage.
seandogue
seandogue
Answer 9 years ago
BTW, when using a DC voltage source, the current through your solenoid based electromagnet will be determined by the applied voltage. I notice you suggested "a higher current at 5V"...that's not how it works.
Your solenoid has a fixed real resistance, so the steady state current (the current after it has been energized for a short period of time) through it is dictated by the applied voltage. This is why I suggest measuring the resistance and calculating the necessary voltage for a given solenoid current
V = I x R
gkohle
gkohle
9 years ago
It's the current flow that creates the magnetic force. As for the thickness, thinner is better because you can create more coils in a smaller space. The only problem is that you risk over heating and melting the protective coating and creating a short that will reduce the number of coils and thus stop the electromagnetic forces (as well as heating up the battery quickly)
rickharris
rickharris
9 years ago
The electron flow (current) does the heating. Power (watts) is voltage times current.
As to the efficiency you may just have to experiment and try both ways. In General more turns more magnetic flux.
ARJOON
ARJOON
9 years ago
high voltage for small wire
