1168Views8Replies
How to power up a crt?
I have a crt from a monitor and I want to power it how do i do that?
I have its flyback connected to a zvs driver, and a computer power supply
Best Answer 9 years ago
Don't bother trying. If you didn't salvage all of what you need intact then you have almost no chance of success. And failure at this level can be lethal. Touch the wrong thing and you get electrocuted. Supply an over voltage and your crt will emit radiation.
Better idea is to start with another monitor and work from that.
Answer 9 years ago
+1 Get a new old CRT monitor, or old CRT television, and start over, maybe using one of these 'ibles:
https://www.instructables.com/id/How-To-Make-A-CRT-TV-Into-an-Oscilloscope/
https://www.instructables.com/id/Make-an-oscilloscope-out-of-an-old-Crt-computer-mo/
https://www.instructables.com/id/Fully-Functional-Television-Oscilloscope/
Answer 9 years ago
He's not kidding about radiation, by the way. Electron beam slamming to a sudden stop is how you make an X-ray machine. TV designers are careful about their voltages and shielding in order to limit that danger.
9 years ago
Positive electrode goes to the anode hole on the CRT and negative return just clip it onto one of the pins at the base of the CRT, one will eventually work. How ever don't expect to be able to feed it a picture signal, that is almost impossible without the original circuit board or the technical know-how.
Just be careful of x-rays from the front of the CRT when there is HV present.
9 years ago
You are aware that you are dealing with potentially lethal voltages and currents, right? (The idea of someone homebrewing a CRT monitor scares me, to be perfectly honest, despite the fact that Heathkit used to sell TVs in kit form.)
Answer 9 years ago
Heathkit sold solid designs with very good instructions on where to put what and where to not touch. But I still never that the courage to build one of the kits that had HV.
Answer 9 years ago
I work very safe and I am very aware that the currents and the voltages I am working with are lethal but I am not scared by high voltage
9 years ago
be clearer. too funny to understand
