Please be more defined.
Do you mean any of the following:
A. How do you burn a program to the PIC?
B. How do you write to EEPROM?
C. How do you write a .hex file to the PIC?
D. How do you write any other file extension (.txt, .jpg, ect.) to the PIC?
If you meant :
A. PICKit 2 works great and is made for it. There are other DIY programmers if you google it or look around here.
B. Same as A.
C. Same as A
D. You don't... If you changed the information to hexidecimal then you could do A.
Good luck.
If it is none of the above please clarify more.
12 years ago
Please be more defined. Do you mean any of the following: A. How do you burn a program to the PIC? B. How do you write to EEPROM? C. How do you write a .hex file to the PIC? D. How do you write any other file extension (.txt, .jpg, ect.) to the PIC? If you meant : A. PICKit 2 works great and is made for it. There are other DIY programmers if you google it or look around here. B. Same as A. C. Same as A D. You don't... If you changed the information to hexidecimal then you could do A. Good luck. If it is none of the above please clarify more.
