205Views5Replies
Author Options:
How to reduce LED drain on battery? Answered
I have a Cree Q5 LED, I established the typical forward voltage is 3.7V and the maximum current is 1000mA. I'm confused as to how I reduce the current, I want it to run at 350mA, I know this is possible, I'm just not sure on how to go about doing this. Can anyone point out how I do this.
Thank you.
Tags:LED
iceng
iceng
9 years ago
You do not say what power supply voltage you are using.
See the circuit for a current controlled driver that can work on your LED
from 5VDC to 35VDC. . . . . . . . . . . . .  A
R1 = 3.50 ohms gives an LED current of 357 ma
R1 = 1.25 ohms gives an LED current of 1000 ma
lemonie
lemonie
9 years ago
Correct answer.
L
sshuggi
sshuggi
9 years ago
What's your source voltage? Anyway, use a resistor and wire them in series.
Vsource-VLED=Vresistor
(Kirchhoff's Voltage Law)
Let's say you have a 9V source. The turn-on voltage of your LED is 3.5V meaning Vr=5.5V.
ILED=Iresistor
(Kirchhoff's Current Law)
You want ILED to be 350mA.
Vr=IrR
(Ohms Law)
Solving for R you get R≈28Ohms for a 9V source. Do this same set of calculations to fit what you have.
sshuggi
sshuggi
Answer 9 years ago
Correction:
R≈16Ohms (I hit 9 instead of 5.5)
jakespikey
jakespikey
Answer 9 years ago
Thanks for your reply. I'm still a bit confused however.
1.) Where did you get 3.5V for the LED to turn on, why aren't you using the forward voltage of 3.7V?
2.) If my source voltage is 3.75 I get R = 6 Ohms at 350mA is that correct?
3.) Okay now pretend I wanted the LED to draw 1000mA am I correct in saying R = 2 Ohms?
4.) Assuming my calculation in question 2 was correct if I have 2 LED's and I want each to draw 350mA. I need two 6 Ohms resistors with the 1 resistor and 1 LED wired together, with the battery connect to them both in parallel. Is this correct?
Thank you, I really appreciate the help :)
sshuggi
sshuggi
Answer 9 years ago
Sorry, misread the 3.5V. I get R= 0.05/0.35=0.15Ohms. However, this doesn't work for the way I've modeled it. The LED is hardly linear, and I was assuming it would be on in this linear model. With the voltage source being pretty much exactly the turn-on voltage, any linear assumption goes out the window. You probably could calculate the right resistance, but the complexity of the model would make it such that you'd be better off just trying different resistors until you get the right one. If you have a multimeter, you can narrow down on a resistor value in 30 seconds or less by just trying different values.
Remember:
In series RT = R1 + R2 +...
In parallel 1/RT = 1/R1 + 1/R2 +...
