1735Views11Replies
Author Options:
How to remove old adhesive from Bakelite plastic? Answered
Recently put back in to use an old Northern Telecom rotary dial telephone.  It works awesome and ironically it has the best sound out of all my phones, huh..  Anyway, the case is Bakelite plastic.  On it was an old label that had its phone number, contact info, yada yada yada...  I peel it off, but under neath the old adhesive made the plastic look matte, as opposed to the original glossy black that the rest of the phone has.  Any idea as to solvents to gently break down the adhesive, yet not effect the old Bakelite plastic?
Re-design
Best Answer 8 years ago
I think you can use mineral spirits, or denatured alcohol. Test it on the bottom. but I think one of the benefits of Bakelite was it's imperiousness to most solvents.
rimar2000Re-design
Answer 8 years ago
Try using lighter's fuel, it is a good solvent. Also gasoline is good.
Re-designrimar2000
Answer 8 years ago
Gasoline is VERY dangerous to use a a solvent. YES I know I did it when I was a kid but I grew up and realized it's about the most dangerous fluid to use for cleanup.
caarnteddRe-design
Answer 8 years ago
Yeah? Off the top of my head, I thought alcohol was worse than gasoline. Without bothering to look up LEL /temperatures, etc. I think gas fumes are heavier and pool in low spots easier, but I'm not sure. All pretty dangerous, and we get a little sloppy when using them sometimes.
kelseymhcaarntedd
Answer 8 years ago
You're the technical expert, but I just looked up the numbers (Wikipedia makes this so easy!).
Gasoline LEL is 1.3% by volume with a flash point of -40 C (yes, that's a "-" in front!). Isopropanol LEL is 2% by volume, with a flash point of 12 C. Gasoline also has a substantially lower autoignition temperature (250 C vs. 400 C), so it's rather easier to ignite by mistake.
What's nice about alcohol is that it evaporates and disperses into the atmosphere readily, reducing the ignition hazard. Gasoline pools as a liquid, then maintains a substantial local vapor concentration, making unexpected ignition all the more likely.
kelseymhcaarntedd
Answer 8 years ago
O_o Well, I did take a fire extinguisher safety class, once. Does that count?
rimar2000kelseymh
Answer 8 years ago
I always carry a fire extinguisher on my shoulder. One must be forehanded.
rimar2000Re-design
Answer 8 years ago
ALL POWERFUL THINGS ARE DANGEROUS. Without exception!
IE: gas, dynamite, nuclear energy, electricity, women, etc, etc.
DreamGreatDreams
9 months ago
toothpaste works great and not only removes the residue from stickers but also as a polish. it can often bring back a dull old finish to a polished shine.
kricketone
8 years ago
just get some WD40 it will remove 90 percent of the glues on the market
kelseymh
8 years ago
Isopropanol or acetone should do the trick for you. Bakelite is, by design, pretty impervious (not to be confused with "imperious" :-).
