101193Views15Replies
Author Options:
How to remove permanent printed designs on glass? Answered
Hi, I have an old diffuser reed bottle which I think could be useful for a future project as it is a colour that would go well with the theme of my room - but it also has the candle company name and rather too much print on the glass.
Is there some way that  I can remove part of the design without damaging the glass or causing too many scratches, it would be a shame to throw it out (we cannot buy refills over here so there's not much else I can do with it).
Thanks.  : )
Vyger
Vyger
Best Answer 6 years ago
A brass wire wheel on a bench grinder will clean the glass of anything not etched into the glass. Brass is softer than glass so it does not usually scratch it. They used to make brass windshield ice scrapers that worked great. But sometimes the glass would get scratched from the grit in the dirt (not from the scraper) so they quit making them.
Test it first on a scrap bottle. Be sure to hold the bottle very tightly as bench grinders have the tendecy to grab things out of your hands and fling them. Your glass could get turned into shrapnel if you are not very careful.
Vyger
Vyger
Answer 6 years ago
Thinking about it what might be safer for you to use is a Dremel tool with a brass wire wheel. It turns slower and will not likely break the bottle.
shyamz
shyamz
Answer 6 years ago
Thanks, I think a friend of mine has one of those so I'll see if it works.
Thanks again. : )
satohari
satohari
1 year ago
Cheap and works on most "logos"
Put it on a plate with a thin layer of vinegar, yes vinegar.
A couple hours and it's already coming off with a sponge or scraping easily with a razor.
Tougher paints may need overnight or a few more hours to cleanly come off, or scraping and another bath in vinegar.
Obs: a few all around paint, tougher like nail polish doesn't come off with vinegar, but try soaking it first for a couple hours, most bottles I tried worked.
marcelo.guedes
marcelo.guedes
Reply 11 months ago
I used apple cinder vinegar and it worked like a charm for me. Thanks!
Lppruett
Lppruett
Reply 4 weeks ago
I tried it all and only Apple cider vinegar worked. 1 hour soak and the ink came off with one wipe of a rag. Thanks Marcelo!
Uberest_Uber
Uberest_Uber
1 year ago
I'm finding this thread five years later but I am using WD40 to soften and lubricate the print while razor blade scraping a printed design off picture frame glass. Seems to be working.WD40 leaves an oily residue, in my experience, so you will have to use windex later. But it's pretty good at dissolving and softening paints and inks.
KushalT2
KushalT2
4 years ago
Dip the bottle in acid i mean mixture of water and acid keep acid more than 70% normal acid for home cleaning purposes can be used keep it for more than 3 hours than rub with a cloth rolled over a wood stick
shyamz
shyamz
6 years ago
Thank you all for your help, I have an old bottle that I can tests some of these ideas on so I'll give them a try.
Thanks again. : )
bwrussell
bwrussell
6 years ago
Some people claim that using sugar as an abrasive works. Similar to the brass wire wheel the sugar will crush before it scrapes the glass, it's just a matter of how well bonded the paint is.
ianbates1
ianbates1
6 years ago
You could try wire wool - test on the bottom first and if it doesn't scratch there you might be ok.
Triclaw
Triclaw
6 years ago
heat and scrape
mole1
mole1
6 years ago
Assuming that solvents - acetone? mineral spirits? - haven't had any effect, I would try (very very! carefully!) scraping it off with a razor bade.
