6410Views12Replies
Author Options:
How to repair corrupted PDF files? Answered
Hi all.
My PC was infected by viruses..
I have cleaned it completely, but many office and pdf files are corrupted and won’t open.
I have tried many many repair programs that I googled but can’t find appropriate.
Thanks for your help in advance!
skuntz32
skuntz32
Best Answer 6 years ago
Instruction for PDF
Toolkit
Click the
"PDF Toolkit" link in the Resources section to download the PDF
Toolkit program. Double-click the downloaded file and extract the contents into
any directory on your local hard drive.
Double-click the
"Setup.exe" file and click "Next." Click
"Install." Click "Finish" when the installation is
complete. The PDF Toolkit program will open automatically.
Click the
"Repair a PDF" button. Click "OK." Click on the corrupted
PDF file to select it and press the "Open" button. The PDF Toolkit
program will repair the corrupted file and add "_fixed" to the file
name, while saving it in the same directory as the corrupted file.
Also some helpful and easy to use resources which may help you to resolve your issue:
Direct
link on pdf online repair service-
https://onlinefilerepair.com/
Next resource also
can aid you to resolve pdf issues:-
http://www.filerepairforum.com/forum/adobe/adobe-aa/pdf/417-%E2%80%8Bdamaged-pdf-file-cannot-open
davisfed
davisfed
4 years ago
While using the system there is a possibility that your PDF
files may become corrupt, but there is nothing to worry about, you can easily
recover the PDF files with the help of PDF File Repair Tool. This application
can easily recover corrupt or damaged PDF files. For more details visit: www.pdf.filerepairtool.net/
Alice Jolly
Alice Jolly
5 years ago
Hi...you can now easily repair corrupted pdf file using special repair tool called PDF Repair Tool. This tool is capable of fixing, repairing or recovering any kind of data related to PDF files. For more information, please visit:
http://pdf.filerepairtool.net
alexsbutler
alexsbutler
5 years ago
Kernel for PDF repair tool is an instant PDF
File Repair utility to fix PDF files corruption issues. With the help
of this utility users can repair & fix corrupt or damaged PDF
documents easily. Download free trial version click here : http://www.pdffilerepair.net
Phillc2
Phillc2
5 years ago
There are lots of reason behind the corruption of PDF file and at the time of corruption user start searching a solution from the help of search engine. So here we provide a best reliable solution which help you to repair and restore your corrupted PDF file.
For more details visit: https://recoveryandmanagement.wordpress.com/2014/09/17/repair-pdf-file-damaged-corrupt/
RyanD15
RyanD15
5 years ago
If you are unable to access your PDF file or it
cannot be opened. This happen due to virus attack, human error,
improper download, network breakdown, abrupt system shutdown etc. PDF
File repair tool repair your corrupt or damaged PDF file easily in
only a few minutes. This software has user friendly interface,so
requirement of any extra technical skill is NIL. To know more about
this software visit here:-http://www.pdffilerepair.net
mpilchfamily
mpilchfamily
6 years ago
If the files where just deleted they can be saved in many cases. But since the files are corrupted you probably won't be able to recover them.
markwillium
markwillium
Answer 6 years ago
"But since the files are corrupted you probably won't be able to recover them"
It is not always right!!
There is a good piece of 3rd party tool (Stellar Phoenix PDF repair) that can repair corrupt or damaged PDF file and recover data from it.
Personally I have tested this tool. If you want to evaluate then download the demo version and test it on corrupt file. It might change your opinion.
http://www.stellarinfo.com/file-repair/pdf-repair.php
Vyger
Vyger
6 years ago
I think this actually might be a cleaver spam.
So, anyone who reads it should keep that in mind. It's most likely an attempt to get you to use the programs or visit the web site. Unless someone legit, a regular user who didn't join just to answer this question, tries it and says so and that it works, you might be buying something in the end.
rickharris
rickharris
6 years ago
This is after the horse has bolted BUT - make REGULAR backups. That way you will loose little.
