146Views5Replies
Author Options:
How to repair (rehydrate) wooden wringer section..........its cracked in places? Answered
Found the top section of a wringer washer made mostly of wood.  The rollers has some cracks in it and would like to know if it can be repaired (rehydrated) to use again on clothes (fabrics)?
Kiteman
Kiteman
Best Answer 4 years ago
It's not a case of rehydration.
Your best bet is to fill the cracks with wood filler, epoxy, glue+sawdust or your own chosen material.
rickharris
rickharris
4 years ago
Use it as it is. It will get wet and dry out again.
if you fill it use a waterproof glue or filler.
Snooze2978
Snooze2978
4 years ago
Thanks for the suggestions. Will try the wood + glue and if that doesn't work, the rubberized solution. Plan B will be to just cling wrap them. Plan to put a thin sock over each of them to be sure no marks transfer to the fabrics, especially the light fabrics.
Thanks all for your suggestions.
iceng
iceng
4 years ago
It could be simply using water and as it slowly rehydrates watch for enlarging cracks that may need a non-expanding waterproof glue mixed with sawdust.
petercd
petercd
4 years ago
Usually one would use olive/mineral oil, the end use precludes that solution though.
I reckon the bare wood will make marks on clothes, try some sort of rubberised coating or perhaps clingwrap them.
