1085Views3Replies
Author Options:
How to scale papercraft and where to print? Answered
We are planning to do several models from Star Wars as Halloween Costumes.
I have a papercraft model of an AT-ST, Darth Vaders Tie Fighter, and an Xwing. And potentially a millenium Falcon.
These are currently 1/16" models.
Our plan is to scale them up to about 6 feet to use as a pattern then put them over cardboard or corrugated board.
What is the best/cheapest way to achieve this? I have them in a locked .pbo file and in pdf
Kiteman
Kiteman
Best Answer 8 years ago
I suppose you could try using Rasterbator to create poster-sized versions - you'd print it out as A4 tiles, glue the sheets together, and then work from there.
steveastrouk
steveastrouk
8 years ago
Project them with a video projector onto the bigger paper ?
rickharris
rickharris
8 years ago
+1
Or you can simply take the model, Draw a grid over it in pencil or something.
Then draw the same grid on a big bit of paper at the required scale:
So to increase size by x 2
Draw small squares at 0.5 inch and big squares at 1 inch
The copy the lines in each square to the bigger grid.
My printer will print out on multi sheets which I can stick together to make big print.
Depending on the complexity - a ruler and protractor should allow you to redraw the models.
