1582Views5Replies
Author Options:
How to secure metal shaft into bearing with larger ID? Answered
A question for mechanical gurus :)
I'm building motorized Igus camera slider based on Kokomonstrum design.
I have a shaft that's 1/4" OD that needs to go inside bearing block that has bearing with ID of 5/16". I know I need some kind of bushing, but ones I bought at McMaster don't fit bearing opening (even tho they are 5/16 OD). What are my options? Tape wrapped around shaft? Epoxy? Can't think of anything else :(
iceng
iceng
Best Answer 9 years ago
Heat the bearing in boiling water ( in a plastic bag if iron ) and
put the bushing in the freezer then try fitting it together.
A
bratan
bratan
9 years ago
Thank you guys for your suggestions, it helped me to find a solution. I found some bronze bushings of the right size in Lowes and was able to evenly file down outside edge (with use of drill press and a file) so it now fits into the bearing!
steveastrouk
steveastrouk
9 years ago
I don't see why a 5/16 bush doesn't fit the hole ? Have you measured them with a vernier ? What is the bush made of ?
bratan
bratan
Answer 9 years ago
bush is plastic (PEEK). Yeah I measured: bearing ID is 0.312", bushing is 0.317"
steveastrouk
steveastrouk
Answer 9 years ago
Being plastic, I'm going to suggest its designed to be knocked in, so its a bit bigger than you'd expect.
Steve
