290Views5Replies
Author Options:
How to set up a heatsink...not inside a computer? Answered
Im thinking of buying a heatsink with a fan on it. If I dont put it in a computer will it work as long as it has electricity? Will it blow cool air on me if I set it up on a stand?
Re-design
Re-design
Best Answer 10 years ago
It will blow room air against you. A heat sink it to take out excess heat from a component and release it into the ambient air. If there is no temp differential there is no heat transfer.
Look into the peltier cooling chips.  They cool on one side and heat on the other when electricity is applied.
Adum24
Adum24
Answer 10 years ago
So I could use that instead with the same concept? I actually saw that online a few minutes after I posted this question.
Re-design
Re-design
Answer 10 years ago
Yes. A peltier chip would cool the air you were blowing across it. A head sink won't cool the air any, it works by being cooled by the air blowing across it.
Adum24
Adum24
Answer 10 years ago
Hey, thnx a lot for the help!
lemonie
lemonie
10 years ago
The heat-sink is a piece of metal, designed to shed heat. If you put heat into it and run the fan it will lose the heat and blow warm air.
*It will not blow cool unless you make it cold.*
The fan will blow air if you power it up.
See here for the sort of thing I think you're after:
https://www.instructables.com/id/Air-Conditioners/
L
