How to view the view of a SQ8 camera on your computer?
So I got this SQ8 camera just for fun. Right now I'm wondering if I can show the the camera's view on my laptop? The SQ8 say it can connect to TV and show it's view, can I do the same with my laptop?
Here is what I conclude: The USB port of the SQ8 provides 8 wires. However, the cable is split into 2 wire, 1 to the USB head (which have 4 wires) and 1 to the plug for the TV (by the look of things, there is only 2). I have no idea how data is transferred, but here is my guess. The USB head will provide power for the camera to charge and the last 2 wire may have to do something with shutting the connection (If I press the on/off button on the camera, my laptop signal the device has disconnected/reconnected to my laptop). The 2 wire that transfer the image to the TV is the yellow head, which I have 0 clue how it works cause I haven't learn about it. My question is: is it possible to take this 2 wire to connect and display my camera's view?
Here are pictures that I took. In the pics there is the port that the camera has and the 2 end of the cable.
12 months ago
I found SQ8 camera useless. It is difficult to figure out what it is doing through the lights. I wish it had connection to some devices android/modem/pc so it it can be programmed or controlled. Without that it is timewasting.
Reply 12 months ago
You are right, I also found it out
12 months ago
Recently, I’ve seen some really awesome and inspiring projects and noticed that the authors were teachers https://ometv.onlhttps://chatroulette.onl
so I thought it would be cool to connect here and share what we're working on with other teachers who also love to tinker and make. I'm so excited to learn about what you all are up to and celebrate your crafty, techie, maker awesomeness! :
2 years ago
The problem isn't a hardware problem but a software problem, the SQ8 is a DVR Camera a Digital Video Security Camera which needs DVR software to work along with the USB cable you already have.
I found that DEBUT
VIDEO CAPTURE AND SCREEN RECORDER Software worked just fine on my PC with
no in-built Camera, but on my laptop with in-built camera I had trouble getting
the software to switch to the SQ8
4 years ago
A Video/Audio Capture & Converter Cable is used to watch video on a PC from things like a camcorder, VCR, DVD player, satellite receiver, or surveillance system. I suspect that the SQ8 composite video works the same way. Sabrent has one of the cheapest https://www.amazon.com/Sabrent-USB-AVCPT-Digital-Video-Adapter/dp/B0011N9QNC
4 years ago
As it is the output of the camera is Composite video via the RCA plug It is possible the USB plug carries video data BUT your going to need some software to untangle it so you can view it.
You could put the SD card in an USB adapter and feed the data in directly. But your still going to need software to view.
