3284Views3Replies
Author Options:
How to wind a step up transformer ? Answered
I need to make an ac step up transformer with an input from the main, output of 400v ac to connect to the a bridge bridge rectifier.
The bridge rectifier number is D35XB60.
iceng
iceng
Best Answer 6 years ago
TommyT1 is not crazy !
A transformer does not create power actually it looses some in performing its transforming job !
So if your step up is doubling voltage 220 VAC => 440 VAC at 30A out that means a 60A input ........ 440 x 30 == 13,200 W == 220 x 60 == 13.2 KVA.
Why 440 VAC ?? ..... well they are standard.
Here is a 440:220 control transformer only 7.5 KVA which is Half your size.
Height 14.75 In., Depth 11.75 In., Width 9.75 In and only costs $1,351.54
And remember you will need two.
Then again starting at 220V 4.5A the output will be 440V 2.25A at 1KVA actually available [ second picture ] for about $156 and you only need one !
mind power
mind power
6 years ago
sorry but there is a little mistake in the information i gave you..............
input current is maximum 5 amps
output current is 1 amp
iceng
iceng
Answer 6 years ago
You have a 220 to 440 VAC transformer and you want a 1A output which means a 2A input [ Remember 2:1 ratio ].
After my long dissertation as to current capacity inverse to voltage ratio.
The transformer power rating 0.44 KVA ~ 1/2KVA seen used for as low as $20 on eBay...
mind power
mind power
6 years ago
input voltage - 220v
output voltage - 400v
input current - 3 to 5 amps
output current - 30 to 34amps
core type - ferrite E core
iceng
iceng
Answer 6 years ago
To design a transformer the window size is needed and will decide how much wire and what size gauge can be placed into that opening.
The core magnetic material BH curve needs to be known.
Ferrite material is made to allow high frequency because of a low loss narrow BH curve... This is Good because it makes a transformer small BUT it is not effective at transforming the 30A high currents you want and you have to generate the high frequency yourself.
Household frequency is 60cps or hertz in USA and 50 Hz in Europe.
TommyT1
TommyT1
6 years ago
call me crazy but W=IxV
30 amps at 400v is 12kw and 5 amps at 220v is 1.1kw
where are we getting these magical amps from? it steps up voltage not current.
for yoursake i hope I'm just crazy
your input current will be basically 10 times your output current
rickharris
rickharris
6 years ago
You need to have more information :
Your transfomer system has:
An input voltage
A, output voltage
An output current
The input current.
Core type.
The step up is the ratio of turns on the primary to the turns on the secondary.
The wire gauge will be related to the current required.
iceng
iceng
Answer 6 years ago
And volt seconds of the core material.
