How to wire 32 3mm LED's in a string?
hi everyone
I am trying to re-wire a lighting fixture at home that stopped working.
I purchased 32 x 3mm clear LEDs and wired them in a row originating at the original LED driver (see details in pic). Unfortunately due to the dissipation of current down the line I cannot get the string to light up. I was wondering if adding resistors will help my issue, and if so how many resistors do I need to add.
What I understand is that the driver is outputting 50volts of direct current (please correct me if I am wrong) then having 32 x 3mm leds of the driver I am pulling 3volts from each bulb (hence exceeding my driver).
My question is if I directly wire this to the outlet 110v AC can I simply add resistors to prevent overload? or should I be doing something else like changing out the driver or changing out the LEDs to 1w LEDs?
Really appreciate any feedback!!
3 years ago
you might be able to run it on ac with a suitable diode to prevent reverse bias . I can see flicker from leds at 60 hz. some people cant.
Answer 3 years ago
that was part of question - if I was to remove the driver out the equation and try and run the 32 leds on ac how many resistors would I need? is it a matter of taking 110volts - 32 x 3v? or am I missing something?
3 years ago
did you pay attention to polarity which side is + or - when wiring the leds?
Answer 3 years ago
Thanks for the response. Yes I connected them positive to negative in a string as this was how the light was originally wired.
3 years ago
reversing polarity can fry an led. ac reverses 60x / second.
