622Views5Replies
Author Options:
How would I set up a trigger on one relay with multiple pushbutton inputs? Answered
I'm looking to set up a 12 volt system that has approximately 12 buttons that will each trigger an individual relay and a shared relay.  So I will have 13 relays (numbered 1-13) and 12 buttons (1 -12) - Button 1 will trigger relay #1 and #13, Button 2 will trigger relay #2 and #13, etc.
Wiring up a single relay circuit is easy enough, and I think I can set it up with an arduino or similar IC, but I'm looking for a discrete circuit design.  Would a simple diode on each circuit leg be enough?  If not, what would I need?
chrispaccord
chrispaccord
Answer 3 years ago
Awesome thanks!
iceng
iceng
3 years ago
Click the pic to see all four relays and the thirteenth relay..
I let you add as many more relays as you want :-)
chrispaccord
chrispaccord
Answer 3 years ago
Awesome, thank you very much for the in depth diagram!
iceng
iceng
Answer 3 years ago
Steve had designed the circuit first...
